replaced heater core........
Old Dec 20, 2007 | 03:45 PM
shott8283's Avatar
shott8283
Default replaced heater core........
now i only get defrost air flow from half of the dash.. the passenger side air flow is really really weak.. wondering if anyone has had the same issue and what it may be.. thanks!
Old Dec 20, 2007 | 03:53 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: replaced heater core........
ORIGINAL: shott8283
sounds like a problem with the vent actuator rather than the heater core.
Old Dec 20, 2007 | 04:04 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
And did you get the damper cable reattached to the door?
Old Dec 20, 2007 | 05:32 PM
johnjokela's Avatar
johnjokela
ialso will be replacing my" @#%@$#%@$"heater core tommorow and this weekend, hope i dont have the same problem, the brass one is better than the aluminum right? sorry couldnt help on the q's, got the brass for 90$ , everyone else had the alumminum , the friggen stealership wanted $254 and change for a heater core hahahahahahahahahahahahah !!!!!!!!!!!!!!
printing out the diy link , anything else i should be aware of ? before i drop a valve and flip out on this project, I KNOW I KNOW IM a thread jacker sorry, hey shot how long did the job take, ive been putting this off for ever......
Old Dec 21, 2007 | 03:35 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: IndyRamMan
ORIGINAL: shott8283
durr I didnt read properly. Yea it sounds like a cable problem, or possibly you stuffed a rag back there and forgot to take it out.
Old Dec 21, 2007 | 06:12 PM
shott8283's Avatar
shott8283
some connection is crossed or some door is jammed.. the drivers side everything works accordingly and really well.. but the passenger side.. when its on defrost all i get is floor air,, and when i put it to "face" it will change and everythign blows correctly.. and obviously on floor it works fine..
Old Dec 22, 2007 | 12:41 PM
johnjokela's Avatar
johnjokela
just a thought when i did mine, the two nuts that hold the heater box to the firewall inside one with ground cable the other on the passenger side, facing up,when i put mine back togeather there was a gap in the heater boxon the passenger side seal and the fire wall,next to that bolt because i didnt have it lined up properly,DID YOU CHECK FOR GAPS ON THE SEALING OF THE HEATER BOXTO THEDASH?just a thought .All i know is after doing this heater core my dash has bigger cracks in it, probally get a dash mat to cover them up
