WHERE IS YOUR OIL PRESSURE AT???
Old Dec 20, 2007 | 03:45 PM
lastrights's Avatar
lastrights
Default WHERE IS YOUR OIL PRESSURE AT???
just wondering where your guys oil pressure is at, mine starts out high and goes a lil under the halfway mark like 35-40, is that ok or is there something going wrong??? thanks guys
Old Dec 20, 2007 | 03:53 PM
rabbler's Avatar
rabbler
Default RE: WHERE IS YOUR OIL PRESSURE AT???
Sounds good to me.
Mine is just slightly above the 1/2 mark when hot using 10w30 synthetic.
7-10 psi is about all thats required at idle.
Old Dec 20, 2007 | 06:14 PM
CALVIN305's Avatar
CALVIN305
60 with 20w50 synth. blend.
Old Dec 20, 2007 | 07:55 PM
OlsenG_360's Avatar
OlsenG_360
my factory dash gauge reads 40psi whenever the truck is running.
my autometer oil pressure gauge usually reads 70-80psi on a cold startup, 45-55 at operating temp while cruising, and 20-30 at operating temp while idling
edit: this is all with Mobil 1 10w30 and WIX filter
Old Dec 20, 2007 | 09:17 PM
dillonjm's Avatar
dillonjm
Mine:
Warm Idle: 35-40 psi
Anything over 8-900RPM: 50ish psi
Old Dec 20, 2007 | 10:04 PM
dhvaughan's Avatar
dhvaughan
at or a little over 40 at rpm. a little under 40 at idle.
Old Dec 21, 2007 | 02:28 AM
v10power's Avatar
v10power
My V10 is at 40 or above at all times regardless if its hot or cold or idleing or WOT
