Idle problem
Old Jan 4, 2008 | 05:17 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: Idle problem
You still could have problem with the cylinder head, even if the compression looks okay. Have you tryed a running compression just on number 1. You should have 75 or higher on a running compression. Also ck the intake manifold for anyvaccum leaks too.
