Oil pressure drops to 0
Old Nov 30, 2004 | 01:24 AM
JohnT99's Avatar
JohnT99
Default Oil pressure drops to 0
I have a 99 5.9 V-8 and the oil pressure gauge reads fine while driving, but at idle it will usually drop to zero, and then the "check gauges" light will come on. This gets old in traffic. The engine sounds fine, nothing abnormal. I have heard the sending units go bad, but it seems to work fine at speed, so is it something more? BTW- where the heck IS the sending unit? Could this just be a contact problem?
Old Nov 30, 2004 | 01:53 AM
Ramtuff's Avatar
Ramtuff
Default RE: Oil pressure drops to 0
Dodge oil pressure gauges have never been know to be accurate. I'd check the pressure with a mechanical gauge first to see if you have an oiling problem or a gauge/sender issue.
Old Nov 30, 2004 | 02:45 PM
steve05ram360's Avatar
steve05ram360
your sending unit is going bad, it's located next to the distributor and is probably leaking into the wiring connector. Change it and you should be fine. Check the wiring to make sure oil hasn't wicked up the contacts and wires and clean them if necessary.
Old Nov 30, 2004 | 03:12 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
my ramcharger hasnt had oil pressure for 2 years....
but the sending unit is expensive for my truck..so to hell with it.
Old Nov 30, 2004 | 04:28 PM
JohnT99's Avatar
JohnT99
Thanks for the replies. I will pick up a sending unit today & see what happens.
Old Nov 30, 2004 | 05:46 PM
JohnT99's Avatar
JohnT99
Got the sending unit but GOOD LORD. I can't even FEEL the sender much less get a wrench on it. [:-]
Old Nov 30, 2004 | 07:28 PM
steve05ram360
you need the sending unit socket to get it out. Plus if I remeber correctly, you'll have to lay on the engine as if changing the cap.
Old Nov 30, 2004 | 08:09 PM
dmrodco's Avatar
dmrodco
Thats the way I got mine out.... Wasnt fun thats for sure. [8D]
