changing drivers side headlight bulb??
Old Dec 21, 2007 | 03:34 PM
cua0's Avatar
cua0
Default changing drivers side headlight bulb??
this is ridiculous. do you have to take out the battery tray and the air snorkel pos to get the damn bulb out? changing the passenger side takes like 2 seconds, the drivers side is buried by so much crap that it seems impossible. it's -15c and i was out there for like 2 hours trying to get this stupid bulb out, my hands are bleeding!! haha
any tricks? please help!!
Old Dec 21, 2007 | 04:45 PM
rabbler's Avatar
rabbler
Default RE: changing drivers side headlight bulb??
If your careful you can pop the headlightassy off the mounting studs with a screwdriver by prying against the body or the turn signal.
Easy to damage the headlight, paint, etc so not recommended but is doable
Old Dec 22, 2007 | 03:39 AM
MMGoose's Avatar
MMGoose
I changed mine no problem.........getting it back on was a little harder to get the ring to sit right.
Old Dec 22, 2007 | 09:45 AM
dhvaughan's Avatar
dhvaughan
on my 01 its awkward, but doable w/o removing anything. do the passenger side first and look at how it works so you are pulling/twisting in the right direction. after you twist/remove the locking ring you have to pull hard, or wiggle it, or pry the bulb thing out.
Old Dec 22, 2007 | 11:49 AM
Sirhilton17's Avatar
Sirhilton17
At least on mine its not hard... just gotta reach around the battery... I did it in like 10 mins if that. I have big hands too...
Old Dec 22, 2007 | 03:02 PM
TheForce55555's Avatar
TheForce55555
You think a second Gen is hard, try replacing one in a 05 CTD, i was scared to tear crap apart cause it was not my truck
