body lift
RE: body lift
i have a 3" BL and i am not sure if i like it. it has pro's and cons to it. the pro's being that the drive line angle isnt increased so its more mechanically efficient than a suspension lift. less wear on u-joints,access to distributor, t-case, tranny, gas tank ect..is ALOT better. the cons are, austhetically the frame is more visible. if you have side/nerf bars then they will look a little funny because they are lower than they should be in realtion to the body since they mountunder the frame body mount brackets. for mine i am having to make brackets to raise them up so they look right. yours may be different. well, this isjust my opinion.
