Deep Tranney Pan --46RE
Old Dec 28, 2007 | 12:30 PM
sawtooth's Avatar
sawtooth
Default Deep Tranney Pan --46RE
A recent Summit Racing catalog is advertising a Hughes deep trannsmission pan for a 46RE/47RE@ a price of$186 plus shipping. It claims 4 qt. extra capacity.
Has anyone had experience with this pan(HUP-HP1580+) page 203 in Jan. Feb. 2008 Summit catalog?
Are their other comparable tranny pans from other companies that are less expensive?
96, 1500, 5.9, 136K miles __primary use pulling a 22 ft. travel trailer or 2 stall horse trailer.
Old Dec 28, 2007 | 02:15 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: Deep Tranney Pan --46RE
You'll get better bang for your buck with a tranny cooler with an electric fan on it.
Old Dec 28, 2007 | 03:19 PM
Silver_Dodge's Avatar
Silver_Dodge
A deep pan is nice, but it can be a double edged sword too. More fluid takes longer to heat up, so you typically have cooler temps with a larger pan. If if you do overheat though, that extra fluid also takes longer to cool down. If you do get a new pan, make sure it has a drain plug in it. A great way to cool down an overheating trans is to simply empty the fluid out (drain plug makes this a peice of cake), and poor in some nice cold fluid in its place.
Old Dec 28, 2007 | 06:19 PM
Cereal Killer's Avatar
Cereal Killer
Are you sure it's a good idea to drain the fluid out of an overheating transmission? It's not that I doubt you... it just seems like that could really cause problems.
Old Dec 28, 2007 | 06:20 PM
Cereal Killer
Also on that "double edged" sword the deeper pan is going to hang down futher potentially putting it in harms way around rocks and tree stumps.
Old Dec 28, 2007 | 07:07 PM
Silver_Dodge
ORIGINAL: Cereal Killer
That's possible, but i've seen it done, and it worked very good. This guys trans was prone to overheating, so he kept a jug of trans cooler in his ice chest in the back of the pickup. When it overheated one time when we were up near Mt. Ouray, he drained the hot fluid into an empty jug, and poored in the cold fluid. Temps shot right down, and he was able to get it to the next town without worrying about it really overheating, breaking things worse. It was a quick fix, but obviously only a band-aid type fix. But it worked in that situation, so I think having the drain plug at least gives you that option to do something like that should the situation warrant it.
Old Dec 28, 2007 | 08:21 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: Silver_Dodge
I just like to pour icewater down the dipstick tube!
Old Dec 28, 2007 | 08:28 PM
Cereal Killer
lol, keeping tranny fluid on ice. Tell me he wasn't a dodge guy
True about the drain plug, that alone makes it worth switching the pan. If I ever have to drop my tranny pan (change the bands or the fluid or whatever) I'd definetly at least put a drain plug in my existing pan.
Old Dec 28, 2007 | 08:58 PM
Silver_Dodge
Actually, it was a GMC, but that does sound like what someone with a Ram would do, knowing our tranmissions the way we all do.
Old Dec 30, 2007 | 09:46 AM
tazme695's Avatar
tazme695
I AGREE WITH THE GUYS ABOVE! SPEND YOUR MONEY ON A GOOD COOLER 12X12 OR BIGGER! THERE IS A ONE WAY CHECK VALVE IN THE COOLER LINE THAT SHOULD BE REMOVED ALSO! JUST DONT CROSS YOUR PRESUIRE AND RETURN LINES! IF YOUR PULLING A 22FT TRAILER I WOULD INVEST IN A TUGGER KIT OR A JR SHIFT KIT SOME REDBACK CLUTCHES! I PULL A 4,000 POUND BOAT AND A TRAVEL TRAILER AND IT WILL SLAP YOU IN THE BACK OUT OF EVERY SHIFT! INSTALLING A DRAIN PLUG IS A GOOD IDEA IF THE TRANNY WAS REBUILT BUT IF IT HAS MILES LEAVE IT ALONE!
