noise in 4WD
Old Dec 29, 2007 | 07:12 PM
gsarmed's Avatar
gsarmed
Default noise in 4WD
Hello. I notice a considerable whine when I'm running in 4WD high. Speeds are between 30 and 50 mph on snowy roads and highways. The truck has never been abused, and it has 115k miles on it. Is this normal? Has anyone noticed this? Thanks.
Old Dec 29, 2007 | 09:34 PM
Ram2K1's Avatar
Ram2K1
Default RE: noise in 4WD
Yeah, I have noticed it, too. I did a post on this a few days ago that you can check out here:
https://dodgeforum.com/m_1098599/tm.htm
Seems that the chain inside the t-case can be a bit whiney. Just as long as you aren't hearing any grinding or clanking, you should be good. I am going to drain my case and refill with MOPAR ATF +4 next week and see if it quiets it any.
Old Dec 30, 2007 | 06:14 PM
gsarmed's Avatar
gsarmed
Cool. Thanks. I was thinking of draining and refilling so I will definately do that soon.
Old Dec 30, 2007 | 06:32 PM
Chopper1's Avatar
Chopper1
MOPAR ATF +4
In the transfer case????
Old Dec 30, 2007 | 06:41 PM
gsarmed's Avatar
gsarmed
Yes. The transfer case. That's what the manual calls for.
Old Dec 31, 2007 | 05:12 PM
Ram2K1's Avatar
Ram2K1
ORIGINAL: gsarmed
+1...that is what I have been told to use...someone said it was so if the seal between the tranny and t-case went bad, there wouldn't be any bad mixing of fluids.
Here is the post:
https://dodgeforum.com/m_1102886/mpa...tm.htm#1102886
