1999 RAM ABS & brake LIGHT on & brake is engaged
Old Dec 30, 2007 | 04:26 PM
rlares's Avatar
rlares
Default 1999 RAM ABS & brake LIGHT on & brake is engaged
Iam owner of a 1999 dodge ram this morning both abs & brake lighton, but also the brakes are engaged,asI drive I can feel the brakes locked ??? Does anyone know if there is a reset sensor button to disengage the brakes?????
[hr]
Old Dec 31, 2007 | 12:04 AM
Dodge Tech's Avatar
Dodge Tech
Default RE: 1999 RAM ABS & brake LIGHT on & brake is engaged
there is no rest this is not a home computer setup
have the codes scanned for the ABS and go from there.
Old Dec 31, 2007 | 11:25 AM
Kev_n_AZ's Avatar
Kev_n_AZ
you may have:
low brake fluid
blown wheel cylinder
faulty rear brakes (drum)
sounds like you need to roll around and check each individual brake at each wheel. jack the wheel up and spin it by hand. does it turn? do you see a lot of wetness behind it?
Old Jan 1, 2008 | 02:05 AM
kurts2's Avatar
kurts2
I'd lean more towards either the master cyl. (and/or associated subsystems such as the proportioning valve) or somthing in the ABS because the brakes are engaged.
