94-01 Alarm install
Old Jan 2, 2008 | 12:19 AM
95ramdan's Avatar
95ramdan
Default 94-01 Alarm install
Anyone install their own alarm? I'm preparing to install a Alarm/Keyless entry/Remote start on mine. Got it all figured out except the door locks. They are reverse polarity and I knowI will have to buy some relays. Anyone do this before? Just looking for some tips beforeI tackle this project.
Old Jan 2, 2008 | 12:50 AM
BoDuke1987's Avatar
BoDuke1987
Default RE: 94-01 Alarm install
yeah, i install ed a bulldog alarm, keyless entry and remote start. i ddin't have to buy relays. it just cut and spliced into the system
Old Jan 2, 2008 | 02:06 AM
1980blackfiveoh's Avatar
1980blackfiveoh
You will need 2 relays if your ram does not have power door locks and you are instaling them. I added power locks to my 80 stang using reverse polarity lock actuators.I think you can splice into the wires if it has power locks allready.
Old Jan 2, 2008 | 03:24 AM
95ramdan's Avatar
95ramdan
My Ram DOES have power locks but the wiring diagram provided with my alarm system shows relays being used.
Old Jan 2, 2008 | 03:41 AM
95ramdan's Avatar
95ramdan
Here is a diagram similar to the one that came with my system.
http://i122.photobucket.com/albums/o...aritylocks.gif
Old Jan 2, 2008 | 01:04 PM
1980blackfiveoh
I think some systems have the relays built in. The picture shows pretty much the same as how I wired my 'stang except I don't have any switches to lock/unlock. The tricky part if finding a good spot to intersect the factory wiring. I would consider doing this in the drivers door if you have room and run the two wires to the alarm from there.Thepassenger side under the dash could be a good spot too or maybe the passenger side kick panel. Have fun!
Old Jan 2, 2008 | 03:21 PM
95ramdan's Avatar
95ramdan
Thanks for the input, I did some reading and my setup doesn't have the built in relays so I do have to buy a couple... Pretty straight forward though so it shouldnt be hard.
