horn issues
Old Jan 2, 2008 | 06:32 AM
dmdenike's Avatar
dmdenike
Default horn issues
my horn is really faint latley, ever since i went mudding it sounds real sissy. Do you think its clogged or filled with water? Loose connection? Relay? Help me out. Maybe it needs a new horn?
Old Jan 2, 2008 | 07:28 AM
aim4squirrels's Avatar
aim4squirrels
Default RE: horn issues
maybe that one of them isn't working. There are actually 2 horns with 2 different tones. check the connections carefully
Old Jan 2, 2008 | 11:39 AM
TheForce55555's Avatar
TheForce55555
I think you will need to buy a new horn. Mud and water plays hell on horns. I would like to relocate mine so i dont have that problem. Mine sounds really weird so i dont even use it anymore
Old Jan 2, 2008 | 11:49 AM
heybuddy1901's Avatar
heybuddy1901
get the dixie horns and your good to go
Old Jan 2, 2008 | 11:51 AM
CSCustomCars's Avatar
CSCustomCars
Speaking of Horn, Mine sounds like a dieing moose. I think the low tone is out. Should I just replace both tones? Cause both arn't looking all too pretty anymore. Being under the truck, they are both rusty as hell.
How would I connect a new set of horns? Wil the universal ones work from Advance or something?
Old Jan 2, 2008 | 01:38 PM
TheForce55555
I would try the univeral ones. all you have to do is hook up two wires, they also come with new brackets
Old Jan 2, 2008 | 02:02 PM
mcss8541's Avatar
mcss8541
They have a new replacement kit at O'Reilly's for about $19 and it comes with 2 horns, brackets (which will mount to your stock ones) and wiring if needed. Just go to the electrical section an they will be there with a red plastic slotted guard cover.
Old Jan 2, 2008 | 02:05 PM
TheForce55555
Why do you need the horn anyway, THe FINGER works just as good
Old Jan 2, 2008 | 10:35 PM
Aubrey's Avatar
Aubrey
Mine sounded like a dying moose too. Too funny. I ended up replacing them. You can check voltage out at them and also check your fuses. In the end, it's relatively cheap for generic replacements and they are easy to install.
Old Jan 6, 2008 | 09:08 PM
dmdenike's Avatar
dmdenike
UPDATE ON HORNS:
So I went out on the powerlines today and there was this like 94 or w/e audi 100? It was all beat up, shot at, rusted, and drove over by rock crawlers and dirtbikes/quads, so i figured, hey why not look for some horns lol. Well il looked under it and there where 2 horns, took out my knife, and cut them bitches out....OMG THESE THINGS ARE SO LOUD. They dont sound dinky like the horns i used to have, they really are LOUD! Just thought ide update.
Sorry for the long post,
Dmdenike
