Had to do it!
Old Jan 3, 2008 | 09:26 AM
greenmachine's Avatar
greenmachine
Default Had to do it!
Well fellas I have been wanting to do this for a long time so here it is....... I ordered it a couple days ago, a little pricey but I do not have to use zip ties or fab any brackets. I can also attach my washer fluid bottle to it unlike with the standard electrics. I also picked up the 180 thermostat and underdrive pulley.
http://store.summitracing.com/partde...p;autoview=sku
Old Jan 3, 2008 | 02:02 PM
98Woo2500's Avatar
98Woo2500
Default RE: Had to do it!
sweet man you areprobably going to get around 10-15hp
Old Jan 3, 2008 | 02:32 PM
greenmachine
ORIGINAL: 98Woo2500
I hope so. That is what I was guessing also.
Old Jan 3, 2008 | 05:08 PM
TheForce55555's Avatar
TheForce55555
THats alot of money for for 10-15 hp, but hey everylittle bit helps
Old Jan 3, 2008 | 05:29 PM
dodgeman22's Avatar
dodgeman22
but not only is it going to add hp, but its going to be so much easier to work on your motor, for example now to change your water pump, just remove belt and take it off before you have to take off fan shroud, then the fan, then the belt and then the pump, and their will be tons more arm space
Old Jan 3, 2008 | 05:43 PM
1BigRamaniac's Avatar
1BigRamaniac
Unless he gets an electric water pump too!
Old Jan 3, 2008 | 05:57 PM
shott8283's Avatar
shott8283
in my slimmer days icould pop 4 bolts, 2 quick connects, remove my fans, and stand between my rad. and my motor and work on it.. rocked..
i should get back into the gym just for that reason.
Old Jan 3, 2008 | 06:07 PM
padodgeram's Avatar
padodgeram
ORIGINAL: shott8283
the saying goes for guys with a gut " need a shed to cover the tool"
