Dodge Ram V8
Old Jan 5, 2008 | 07:55 PM
Silver_Power's Avatar
Silver_Power
Default Dodge Ram V8
Hey guys planning to get a donor truck and swap my V6 for a V8 what Liter is the V8.. not wanting the cummins.. or what is the largest V8 i can squeeze in my 99 Dodge ram 1500?
Any info would be awesome!
Old Jan 5, 2008 | 08:42 PM
emericaskater285's Avatar
emericaskater285
Default RE: Dodge Ram V8
well if your gonna go the donor way out of another ram 1500 your choices are without going to desil are 4.7(idk if it would work) 5.2 5.7(hemi out of 2003 and up years) or a 5.9(i would go with)
i would say go with the 5.9 first choice or if you have the money go for the 5.7 hemi but idk how that install would go cause you would probly have to get a new computer in the car or complicated wires idk..... but go with the 5.9 or if not that go for the 5.2 the 4.7 engine is way too ***** for my likings.
Old Jan 5, 2008 | 08:49 PM
Cereal Killer's Avatar
Cereal Killer
The 4.7 and 5.7 are 3rd Gen truck motors and are not going to be anywhere close to a direct swap.
They 5.2 and the 5.9 will swap given you have PCM and wiring harness, radiator, transmission, and driveshaft. Hopefully I'm not missing anything.
If you're going to go through all that trouble you should look for a 5.9 so you don't have to do it all over again when the 5.2 leaves you curious as to what your truck may have been...
Also if you plan on doing any engine work it would be better to do it now before you put it in the truck. If I were you I would keep your truck the way it is for now, go out get the donor truck, pull all the parts off of it you're going to need, then part the rest of the donor truck out for $$$. Use that money to build your new 5.9, and possibly bullet proof your new tranny. Once everything is gone over, restored, and painted it'll be time to do the swap.
Old Jan 5, 2008 | 10:54 PM
Silver_Power
Yup.. was my plan... im going for the 5.9.. thnx for the info
