Truck Died---Weird
Old Jan 9, 2008 | 09:36 AM
Ram2K1's Avatar
Ram2K1
Default Truck Died---Weird
This morning, I started my truck andbegan clearing off the snow to go to work. When I got in to leave it was idling around 700-800 rpms and sounded/felt like it had a little miss in it. Then I put itin 4HI, shifted into reverse, and while sitting with my foot on the brake...it died. So I put it inneutral, started it back up and went on to work. After I got to work, I sat in Park with it idling between 500-600 rpms...no miss, idling smooth. That has never happened before, so I don't knwo what the deal is. I bought the truck in August of last year, and it has about 85K on it now. I would think the dealer would have tuned it up, but who knows. Any ideas?
Old Jan 9, 2008 | 12:09 PM
steve05ram360's Avatar
steve05ram360
Default RE: Truck Died---Weird
IAC motor sticking... If it continues, you might need to swap it out.
edit: oops, forgot to mention that a dirty TB can also cause a stall... it might need a cleaning.
Old Jan 9, 2008 | 12:40 PM
Ram2K1's Avatar
Ram2K1
Is this what you are talking about?
http://store.summitracing.com/partde...p;autoview=sku
That isn't too bad I guess. What is a good way/product to clean the TB?
Old Jan 9, 2008 | 12:54 PM
sandmanmi's Avatar
sandmanmi
ORIGINAL: Ram2K1
yup thats the iac motor.its located on theback of the tb.i use spray tb cleaner that you can get from any auto parts store and a old toothbrush to scrub it clean. it works good
Old Jan 9, 2008 | 12:56 PM
steve05ram360
yup, that's the one. start by cleaning the TB before spending anything on replacement parts. (you can also possibly reuse the TB gasket if it isnt torn). any TB cleaner will do to clean the TB. I personally have no preference.
Old Jan 9, 2008 | 05:54 PM
Ram2K1's Avatar
Ram2K1
Where do you find a TB gasket? I looked on Autozone.com and Summitracing.com and did not find one...
Old Jan 9, 2008 | 07:01 PM
steve05ram360
the auto parts stores should have it, dealer will for sure. shouldnt be more than $5 bux.
Old Jan 9, 2008 | 07:15 PM
Ram2K1's Avatar
Ram2K1
Thanks. I think I'll buy one before hand just in case.
Old Jan 9, 2008 | 09:24 PM
turkeyhunter1962's Avatar
turkeyhunter1962
After working on my truck as much as I have I have a box of miscellaneous gaskets. In addition to these extras each time I do anything with the throttlew body I replace the gasket. Just so I always have one I buy them 6 at a time from NAPA. Cost about $2 each. I would not recommend re-using a throttle body gasket. You're just asking for it to start leaking and for the price it's cheap insurance.
Old Jan 10, 2008 | 08:24 AM
Ram2K1's Avatar
Ram2K1
That sounds good. I got a NAPA here, so I may just go there since they have them for sure. Anymore, you never know about Autozone...
