speaker wire
Old Jan 9, 2008 | 07:27 PM
dropem254's Avatar
dropem254
Default speaker wire
So i bought some speaker wire from radioshack for my two tens i have in my truck (wire that goes from amp to subs).. Does it matter what guage I get.. I got 18.. also another dumb question.. I've seen speaker wire that has one clear wire and the other with a black line on it. I know black goes to neg. and the reg. clear goes to pos. The wire i got from radioshack has a white line instead of black.. Is it still the same? just a color diff. Sorry for the dumb questions.. thanks
Old Jan 9, 2008 | 07:34 PM
BIGRED97's Avatar
BIGRED97
Default RE: speaker wire
wire is wire bro. as long as the gauge is the same. copper condcuts with copper the color doesnt matter. just make sure you follow the pos and neg. are the same all the way thru.
Old Jan 9, 2008 | 08:56 PM
xskylinedx's Avatar
xskylinedx
Yep it doesn't matter if you put the white stripe on the pos or the neg as long as you match it up to the other pos or neg. Your best bet is to stop by a car stereo shop and tell them what you have for subs along with how much power your pushing to them. They will easily be able to tell you what guage wire will work to your benefit.
Old Jan 9, 2008 | 09:14 PM
blkbaretta's Avatar
blkbaretta
I'd say the 18 gauge is fine for just wiring up the speakers. Your really wouldn't need more than that unless you are pushing massive amounts of power to some huge speakers, but I'd say you're clear. Just match positive from the amp to the positive on the speaker and the same with the negative and you'll be good to go.
Old Jan 9, 2008 | 10:26 PM
dropem254's Avatar
dropem254
cool cool thanks guys
Old Jan 9, 2008 | 11:31 PM
Rampant 150's Avatar
Rampant 150
I usually use 14 or 12 gauge wire. If your subs stop working for some reason, check your wiring for continuity first.
