ENGINE CODE INFO
Old Jan 14, 2008 | 09:29 AM
BRETTM's Avatar
BRETTM
Default ENGINE CODE INFO
anyone have any info on pulling the codes without buying a tool?? my check engine came on the other day. i have in the past just grouinded the ALDL connector under the dash and made the engine light blink in other app's before. can my 2001 ram be done? if so can someone tell me how? and is there a list of the codes listed anyplace? thanks in advance......
Old Jan 14, 2008 | 09:33 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Default RE: ENGINE CODE INFO
2001 is an easy check. I have to assume that you have the electronic trip meter. Follow this and you'll be able to pull your code(s).
Without starting your engine.
Turn ignition on, then off, then on, then off, then on.
The system will do a check and provide you with the exact ODBCII codes on the trip meter. Write them down.
Once you have them do a search on the forum here to identify what they mean and how others have fixed them.
Old Jan 14, 2008 | 12:03 PM
BRETTM's Avatar
BRETTM
i don't have the overhead trip meter at all. mine is just the overhead light only and glasses holder??
Old Jan 14, 2008 | 12:04 PM
Silver_Dodge's Avatar
Silver_Dodge
It shows you the codes on your odometer, not the overhead console.
Old Jan 14, 2008 | 12:10 PM
chet's Avatar
chet
I do the key trick to find out what it is and either fix it or take it to autozone to have a more detailed explination and the have them cleared.
Old Jan 15, 2008 | 08:30 AM
turkeyhunter1962
Once you pull the codes off the computer you can clear them by re-setting your computer yourself. Disconnect the battery and turn your ignition switch to on for a couple minutes. This will re-set the ECM. Once you restart the truck you may notice it running slightly different, but that will change as the computer re-learns how your engine runs.
