Stuck Spark Plug removal solution
Old Jan 14, 2008 | 04:37 PM
CPTAFW163's Avatar
CPTAFW163
Default Stuck Spark Plug removal solution
Hey guys,
When doing my MSD i changed the spark plugs. One was stuck and I tried P Blaster, didn't work, then I took canned air, turned it upside down to spray liquid nitrogen on the plug and whacked the socket with a hammer so it might crack the rust and contract the plug threads, then P Blaster. That didn't work. So finally i gave up and i took it to a place to get removed. In 20 mins they had it out with a Breaker bar and a special concoction. The plug was rusted to the head.
Special concoction:
P Blaster and Royal Purple motor oil. They said it is a specific ratio, but didn't tell. Have you guys ever heard of that?
Old Jan 14, 2008 | 05:47 PM
Tarner's Avatar
Tarner
Default RE: Stuck Spark Plug removal solution
[sm=confused06.gif]I think they're full of #@it.
Old Jan 14, 2008 | 06:44 PM
padodgeram's Avatar
padodgeram
anything is possible.. even if they **** on it and broke loose.. as long as it got broken loose not broken in the head..
Old Jan 15, 2008 | 08:27 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Now that you're running the MSD, you should no longer have problems with stuck plugs. I say this because with the hotter ignition from the MSD, you really need to check the plugs more often than you did with the stock ignition. I also run an MSD ignition so I pull and gap, or replace my plugs every spring and fall. No stuck plugs for me.
Old Jan 15, 2008 | 09:15 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Put some anti-seize on the plug threads to prevent future seizure issues.
Old Jan 15, 2008 | 09:35 AM
SilverRam_01's Avatar
SilverRam_01
ORIGINAL: VWandDodge
Or to glue the plugs into the head[&:]
