anyone running this set-up?
Old Jan 15, 2008 | 04:03 PM
asimpson97d's Avatar
asimpson97d
Default anyone running this set-up?
Just wondering if anyone is running an MSD offroad ignition box, offroad rev limiter, and blaster ss coil....the reason being is I am getting a code P0351 for coil pack problem and I do not have coil packs...the comp has been reflashed by hughes and they assure me its not the comp...the programming guy said that the coil was to hot and could burn up the comp....HELP!!!!!!!!! this is pissin me off...
Old Jan 15, 2008 | 04:20 PM
padodgeram's Avatar
padodgeram
Default RE: anyone running this set-up?
what year is this truck ? i ran msd 6a with ss blaster no issues .
Old Jan 16, 2008 | 05:04 PM
asimpson97d
The truck is a 1997. I called MSD and Hughes. Between the two... I think we have it figured out...I ordered the part and will get it in a few days..we shall see.
Old Jan 16, 2008 | 05:31 PM
steve05ram360's Avatar
steve05ram360
had it, loved it, hated swapping out the accell cap & rotor and I ended up going back to the mopar cap & rotor and all was good.
you will be swapping them about every 20~25k miles though so be prepared.
Old Jan 16, 2008 | 08:04 PM
shott8283's Avatar
shott8283
you need to run the tach adapter from MSD.. i had the same problem on my 01.. runin the 6A and a B3 ... although my CEL didnt pop .. for me i got a hidden code.. the DTC would stay in my pcm but wouldnt nock my CEL.. anytime i would hook the hypertech up to it would say 1 DTC reported.. and it would be the 351 code.. i installed the tach adapter in the MSD system and it took care of that problem
https://dodgeforum.com/m_405881/tm.htm
thats the write up i did on my 6A install.. although i came across the tach adapter after i wrote it up...
