POWER DOOR LOCKS
Old Jan 15, 2008 | 08:31 PM
DONNYO's Avatar
DONNYO
Default POWER DOOR LOCKS
WHAT KIND OF POWER LOCK SYSTEM IS ON A 1994 RAM 1500? IS IT REVERSE POLARITY OR MULTIPLEX? OR SOME THING ELSE.IM CONFUSED
Old Jan 15, 2008 | 08:49 PM
EricCartman's Avatar
EricCartman
Default RE: POWER DOOR LOCKS
I'm pretty sure it's a 5-wire reversal system.
Old Jan 15, 2008 | 08:52 PM
padodgeram's Avatar
padodgeram
ORIGINAL: DONNYO
just installed a remote start / locks.. its reverse polarity .. it is on my 96 im sure its the same on yours
Old Jan 15, 2008 | 09:02 PM
DONNYO's Avatar
DONNYO
THERE ARE 5 WIRES. 2 SEEM TO BE JUST GROUND, 1 IS CONSTANT 12V,THE OTHER 2 ARE FOR THE LOCK AND UNLOCK.THEY ARE NEGATIVE UNTIL YOU HIT THE SWITCH, THEN GOES TO 12V'S LET GO OF THE SWITCH AND BACK TO NEG.
Old Jan 15, 2008 | 09:13 PM
jakkyl's Avatar
jakkyl
Old Jan 15, 2008 | 09:15 PM
DONNYO's Avatar
DONNYO
YES IT IS. I ALWAYS TYPE IN CAPS. THE BIGGER THE BETTER
Old Jan 15, 2008 | 09:18 PM
EricCartman
ORIGINAL: DONNYO
That is a 5 wire reversal system.
This is probably not what you are installing, but download this... http://akamaipix.crutchfield.com/Man...514CG650I5.PDF
Page 24 of that PDF file talks about 5 wire reversal systems and explains how they work.
Good luck,
Cartman
