2500 leaf springs on a 1500
Old Jan 16, 2008 | 11:28 PM
CPTAFW163's Avatar
CPTAFW163
Default 2500 leaf springs on a 1500
Someone told me that I could get 3 inches of lift if I installed leaf springs from a 2500 on my 1500. I currently have blocks as my rear lift and I don't like them because they tend to shift. WHat do you guys think? Or let me know what other parts are available for 300 dollars or less.
Old Jan 16, 2008 | 11:34 PM
padodgeram's Avatar
padodgeram
Default RE: 2500 leaf springs on a 1500
You could go that route.. i think the 1500 spring is 2.5" wide and on the 2500 is 3" wide gotta cut the shackles to make em fit .. or you can do a shackle flip or the cheapest of all is to do a AAL ..
Old Jan 16, 2008 | 11:39 PM
CPTAFW163's Avatar
CPTAFW163
Thanks for the info
It shouldn't be hard to make the shackles fit. I won't be able to cut them though since i don't have the tools. But I wonder if it would still give me a 3 inch lift.
Thanks.
Old Jan 17, 2008 | 12:10 AM
spaz_22's Avatar
spaz_22
...probably not....i wouldn'treally go through the trouble since they are 3 inches....they aren't probably going to give you anymore lift then your regular springs....i know 2500's have a 4.5 inch block....if you want to lift the rear get a 3 inch aal and it will also stiffen up your rear end as well
Old Jan 17, 2008 | 12:26 AM
BIGRED97's Avatar
BIGRED97
i just did this;. not the 2500 leafs. but i just got an AAL and new front coils. all around for about 200$ after shipping. the springs i picked up off one of the guys on here who was selling it. i bought new shocks which were about 300$ but i got the Bilstein 5100 for a 2in lift. apparantly stock height shocks for upto a two lift but i wanted the higher stiffer ride. i really like the way it rides! i need to get some pics of my truck on here. but if you look around you can find a cheap two in lift. i got the AAL from autoanything.com i think 80$ and the coil springs for 100$ shipped slightly used. just look around.
Old Jan 17, 2008 | 07:10 AM
JBs DAK's Avatar
JBs DAK
I've got 2500 on the front and back of my 1500.
(Put them on there for plowing). it gave me about
a 2-1/2" lift. Also got a bigger tire and that gave me
a total of 3". .. Side-note; If I tow or, if I put the plow
on now, there is little or no sag in the front or back with
these springs.
