power steering problems
Old Dec 8, 2004 | 12:49 PM
james ram's Avatar
james ram
Default power steering problems
yesterday my ps shat out on me....
bought the pump installed it got everything laced up etc...
when i started it, there was a rhythmic noise, almost like a banging...
i checked it out and nothing appears to be hitting against anything else (fan blade not hitting anything, pulley looks to be clear of everything)
could this be a result of air in the lines?
any help appreciated, thanks in advance.
Old Dec 8, 2004 | 02:41 PM
Ramtuff's Avatar
Ramtuff
Default RE: power steering problems
It could be air in the lines or a totally unrelated problem. Did the new pump come with bleeding instructions (it should have)? Start the truck up, and turn the steering wheel lock to lock a dozen or so times and then check the fluid level. Add fluid and repeat. Then keep an eye on the fluid level for a few days. The pump is the high point of the system, so it should be pretty easy to get the air out.
Old Dec 8, 2004 | 02:46 PM
Snafu's Avatar
Snafu
Yah, it sounds like cavitation caused by air in the system. This is very much bad. Bleed it out like Ramtuff said.
Old Dec 8, 2004 | 04:17 PM
james ram's Avatar
james ram
it did come with bleeding instructions but i disregarded them :ashamed:
it was late, i wanted to go to bed, that noise scared the **** out of me (last thing i wanna do is spend more $ on repairs 2 weeks before Christmas) so i cleaned up my tools and went to bed...
ill try bleeding it tonite if i get a chance, otherwise tomorrow nite.
thanks for the help
Old Dec 8, 2004 | 04:52 PM
Snafu's Avatar
Snafu
Could be worse. Yesterday we nuked a brand new $5,000 electric motor cause nobody primed the hydraulic pump it was turning... Cavitation is hard on equipment.
Old Dec 10, 2004 | 12:35 PM
james ram's Avatar
james ram
you guys were right, i ran it a little cranked the wheel back and forth to get the air out and she's working like a new truck
thanks for the help!!
