center bearing assembly
Old Jan 18, 2008 | 04:03 PM
Ramsrush's Avatar
Ramsrush
Default center bearing assembly
How much up and down and side to side movement is allowable on the center bearing assembly.Have a vibration.
Old Jan 18, 2008 | 04:27 PM
Ramsrush's Avatar
Ramsrush
Default RE: center bearing assembly
Does any one please have any insght on this subject?Ihave changed the center bearing assembly twice before(100-150K is what they lasted)but they were destroyed. This time it just seems to have alot of play in it.
Old Jan 18, 2008 | 04:54 PM
charlie1935's Avatar
charlie1935
I would think they should last longer than 50,000 or so. Is the truck lifted? If it is check or have the U-joint angles checked.
Old Jan 18, 2008 | 05:31 PM
Ramsrush's Avatar
Ramsrush
No the truck is not lifted it is stock and I meant they lasted 100 to 150K X 2 each.Factory one makes 1 and I have put two on it=3.My truck has almost 405K on it now.
Old Jan 18, 2008 | 05:34 PM
Ramsrush's Avatar
Ramsrush
Thanks for the fast repley charlie 1935
Old Jan 18, 2008 | 09:44 PM
Ramsrush's Avatar
Ramsrush
anyone else?
Old Jan 18, 2008 | 10:10 PM
master tech's Avatar
master tech
Site Moderator & Tech
There a tsb to replace two piece driveshaft to a one piece. TSB 03-05-96, You can have the dealer bring the tsb or I can send it to you. just send a pm. Leonard
Old Jan 19, 2008 | 04:41 AM
Ramsrush's Avatar
Ramsrush
ORIGINAL: Ramsrush
I saw the TSB.It's for the 2500 model. I was just wanting to know how much play is allowed.
Old Jan 19, 2008 | 04:43 AM
Ramsrush's Avatar
Ramsrush
ORIGINAL: Ramsrush
ORIGINAL: Ramsrush
ORIGINAL: Ramsrush
