V10 runs rough
Old Jan 18, 2008 | 06:32 PM
rockr's Avatar
rockr
Default V10 runs rough
this truck has always been a PAIN since i owned it in 03[:@]
i get a code for EGR valve, since i can't remember how long. it is way under the intake plenum which looks to be a biatch to take off so i been avoiding that little job. would any prob with EGR cause it to run rough?
i changed the plugsand wiresa few months ago. plugs looked ok, nothing unusual.
it seems to run rough when cold, then clears up a bit when warm. it really misses when in overdrive and i try to give it gas. runs better if i lock it out of OD.
any thoughts?
thanks
Old Jan 18, 2008 | 08:45 PM
TheForce55555's Avatar
TheForce55555
Default RE: V10 runs rough
Well if its throwin an EGR code then something Screwed up with the EGR fix or replace
Definitely your problem
