Truck hesitating on 1/4 tank of fuel
Old Jan 19, 2008 | 02:47 PM
jprimrose's Avatar
jprimrose
Default Truck hesitating on 1/4 tank of fuel
have a 94 ram that run's fine till it gets down to a 1/4 tank of fuel then it wont go over 20mph without backfiring and shaking. Noticed that if it sat overnight it would run fine for about 5-10 mins before it starts to run like crap. I was thinking it was the fuel filter but want to see if anyone else has had the same problem or can lead me in the right direction.
Thanks
Old Jan 19, 2008 | 06:50 PM
MMGoose's Avatar
MMGoose
Default RE: Truck hesitating on 1/4 tank of fuel
It sounds like you have some build up in the bottom of you tank. I never let my truck go below 1/4 tank, just because of this problem.
Old Jan 19, 2008 | 07:02 PM
dhvaughan's Avatar
dhvaughan
you might try a few rounds of gas treatment to see if it helps. look for one that absorbs/removes water. maybe use a heavy dose on a 1/4-1/2 tank of gas. it might help and its worth a shot.
Old Jan 19, 2008 | 08:19 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: dhvaughan
I don't see how this would help since gas floats on water, because if there were water in his tank then it would hesitate more often. I think the tank needs to be dropped and cleaned. It wouldn't hurt to clean and inspect the fuel rail as well.
Old Jan 20, 2008 | 12:59 AM
spitfireram's Avatar
spitfireram
try some stuff called Heet...its suposed to take water out of the tank..u will find it at the parts store..its it seemed to work for me.
