Will 34"s fit?
Old Jan 21, 2008 | 12:02 PM
johnnyrocket5363's Avatar
johnnyrocket5363
Default Will 34"s fit?
I want the 3" sky jacker lift kit. On their tire chart, they say 33's or 34's for that lift. Does anyone know what it takes to fit 34's? If it's minor modification, it may be worth it...
Old Jan 21, 2008 | 01:02 PM
2 Marks's Avatar
2 Marks
Default RE: Will 34"s fit?
33's fit stock on a 1500. You'll get 35's to fit no problem.
Old Jan 21, 2008 | 02:21 PM
Silver_Dodge's Avatar
Silver_Dodge
35's will fit with the Skyjacker 3", but you will rub under almost normal driving conditions, forget about off-roading it. 34's will probably fit, but I think you will have rubbing still. What size are you looking to put on (like how wide)? What rims do you have (stock, aftermarket). What's the backspacing if aftermarket. All these things will make a difference as to whether or not you can run 34's with out much rubbing.
Old Jan 21, 2008 | 02:48 PM
Guy01RAM360's Avatar
Guy01RAM360
I just put on 34's (305/70/17)on my off-road 01, with factory 17x8 rims, which is about 2" inch lift over non-off road editions, no rubbing and probably could have squeezed 35's if I had wanted.
Old Jan 21, 2008 | 04:29 PM
zique's Avatar
zique
I fit 35's w/ my 3" (before the extra spacer) and didn't have a single rubbing problem (even at full lock). However, that is with my 3.75" BS on the 15's. The 17's from an Off-road is what I had first, and I could tell the BS was not quite as suitable.
Old Jan 21, 2008 | 05:23 PM
Silver_Dodge
Off-road edition rims have 5.25" of backspacing.
Old Jan 22, 2008 | 12:06 PM
zique's Avatar
zique
That makes sense. That's a full 1.5" more my tires stick out now then.
Old Jan 24, 2008 | 09:24 AM
johnnyrocket5363
I want Ulra Wheels Thunder: Size : 17x9, Backspace : 4 1/2, Offset : -12, Bolt Circle : 5-5 1/2. I would like to go with at least 34"x 12.50" tires....
Old Jan 24, 2008 | 06:22 PM
johnnyrocket5363
My buddy at the tire shop said that a metric size equivelent to a 34.6 or so will work....
Old Jan 24, 2008 | 09:24 PM
nhlbill's Avatar
nhlbill
Seems like so long ago and it was only 2 years, but the first lift I put on my truck was a Rancho 3". I put 295/75/16's (34's) on a 16" x 8" rim with 4" backspacing and it did not rub, even off road.
But the big thing that has already been said is that wheel size and backspacing have as much to do with what fits as lift does, so chose your wheels and tires carefully.
