dead truck no bus
Old Jan 21, 2008 | 09:15 PM
vikdale's Avatar
vikdale
Default dead truck no bus
My truck dies and wont start back up for about 5-10 min in the dash it reads no bus . I've changed the relays and checked all the grounds [i think] still is the same. Had the truck at the local shop and can't find any codes or anything wrong. i'm not sure where to look or what is wrong is there any help
Old Jan 21, 2008 | 09:32 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: dead truck no bus
Try unplugging sensors, TPS, crank sensor and a/c transducer. these are all 5 volt feed to the pcm.and see if your cluster just shows the odometer.
Old Jan 21, 2008 | 10:02 PM
dr_destructo's Avatar
dr_destructo
Mt truck did the same think @ a month ago. Check the 3rd connecter from theleft on the pcm(firewall,passenger side). Mine was loose. I think its black. Mine was loose and had some corrosion. Contact cleaner and some dielectric grease and no problem since. Hope that helps...
Old Jan 22, 2008 | 12:45 AM
rabbler's Avatar
rabbler
ORIGINAL: master tech
Good advice above
MAP, cam/sync and trans temp sensorscan cause the above too.
The bus draws it's power from the same 5v as the sensors.
Crank sensor is most comon for this condition
Old Jan 22, 2008 | 07:51 PM
vikdale's Avatar
vikdale
thanks i'll try these things and see what happends. where is the crank sensor located on my truck? The bad thing is it only does it when it wants too. So i'll wait for it to mess up then i'll try these things.
