starter question on 2000 ram 1500
Old Jan 22, 2008 | 12:41 PM
detdodge's Avatar
detdodge
Default starter question on 2000 ram 1500
Hey everyone,
I have a little problem that has knocked my truck out of commision for a little bit. One day the truck wouldn't start. When you try to turn it over, it only clicks once. I put my fingers on the starter relay and could feel it click once. It's not the battery because the lights don't dim and the radio stays fine when I try to turn it over. I bought a new starter relay and that didn't seem to do anything.
I'm thinking it's the starter. However, I'm horrible at truck maintenance and I was hoping someone knew if it sounds like the starter IS the problem. If so, how do I find out what I need and how to remove it so I can get it tested and (hopefully not) replaced?
Thanks everyone for the help in advance.
Old Jan 22, 2008 | 12:48 PM
lastrights's Avatar
lastrights
Default RE: starter question on 2000 ram 1500
hey buddy , i have a 2000 dodge ram, and 2000 dodge ram has this problem, that the starter fuse keeps blowing, and you have too put in a starter solonoid, i mean you can keep on putting a fuse in but its just going too blow, and dont put in a higher amp in, it will do lot of damage.
