00' 5.9L Idle question/problem
Old Jan 23, 2008 | 08:47 PM
Bigogre55's Avatar
Bigogre55
Default 00' 5.9L Idle question/problem
My truck idles at around 600 RPM and will idle a little sparatically, jump up and down about 25-50 RPM randomly at idle. I had the idea that it might be spark plugs so I reaplced them awhile ago along with the wires, cap and rotor. I used bosh platnum plugs and autolite wires(I think but definately wasnt the cheap ones). but after I did this it didnt fix the problem. I ran premium through the engine one time and added some fuel system cleaner(lucas) to the tank and still idled similar to before. Anyone have any suggestions to what I can do to make the truck idle smoothly. Champion plugs? different wires? hit it with a hammer till it does what I want it to do?
Just for extra info it is an 2000 ram 4x4 with 57500 miles on it. all of this was going on before and after a synthetic oil swap in the whole powertrain and tune up. Thanks for the help.
Old Jan 23, 2008 | 08:51 PM
spitfireram's Avatar
spitfireram
Default RE: 00' 5.9L Idle question/problem
sounds like ISC (idle speed control) replace it or clean it...
Old Jan 23, 2008 | 08:52 PM
jasonw's Avatar
jasonw
Site Moderator
I say hit it with a hammer until it understands what you want it to do.
Old Jan 23, 2008 | 09:10 PM
Bigogre55's Avatar
Bigogre55
ill try and do that (ISC) as soon as possible (12 hour work days 7 days a week)and then if that doesnt work I will pull out the old faithfull hammer.
thanks
