? about tow package
Old Jan 23, 2008 | 09:15 PM
Ram2K1's Avatar
Ram2K1
Default ? about tow package
Hey guys, I was just wondering how to tell if my truck has a factory tow package. It does have the receiver/hitch and button on the end of the shifter to turn off OD, but that seems standard on all Rams. What is a sure-fire way to tell??? Could I just check for a factory tranny cooler? If so, where are those located?
Thanks all
Old Jan 23, 2008 | 09:39 PM
rlbdodge318's Avatar
rlbdodge318
Default RE: ? about tow package
im not sure if this is an accurate way to tell but my truck has a mopar plug on the hitch i also have a trans. cooler mounted in front of my radiator and when i went to get a shift kit put in the shop said it already had one but my truck was pre owned so the could have been add ons
Old Jan 23, 2008 | 09:55 PM
dsertdog56's Avatar
dsertdog56
Tow package trucks should be equiped with H.D cooling, trans cooler and Power steering cooler. Depending on the year, you may have 3:92 gears as well on a1500, although that's not a hard/fast rule.
Old Jan 23, 2008 | 10:00 PM
Parts/Service's Avatar
Parts/Service
PM me the last 8 digits of you VIN and I can tell you if it have the tow package....
Old Jan 24, 2008 | 01:14 AM
lucas3397's Avatar
lucas3397
I believe if you a trans temp light that means you have a trans cooler which also means factory tow package.
My light is on the bottom right area of the heat/air controls.
And of course it should come on when the key is first turned on
Old Jan 24, 2008 | 06:59 AM
2 Marks's Avatar
2 Marks
The tow package also has a high output alternator.
Old Jan 24, 2008 | 08:25 AM
Ram2K1's Avatar
Ram2K1
ORIGINAL: lucas3397
I do have a trans temp light flash comes on when I start it up, but it is located on the instrument panel, underneath the tach. I haven't seen anything mounted anywhere that looks like a factory tranny cooler, but where exactly are the factory ones located?
Old Jan 24, 2008 | 10:24 AM
sawtooth's Avatar
sawtooth
You might E-mail Dodge and request a build sheet. Might take a day or two.
http://www-5.dodge.com/wccsapp/unive...amp;category=R
Old Jan 24, 2008 | 10:53 AM
lucas3397's Avatar
lucas3397
Yeah my truck is 4 years older and has the old instrument panel
Old Jan 24, 2008 | 12:04 PM
Ram2K1's Avatar
Ram2K1
Well, I have a build sheet for it, but it doesn't say anything about a tow package. However, I don't know if I trust it 100% or not, because it also says I have the 231HD t-case when I actually have the 231D.
