4wd slipping
Old Jan 25, 2008 | 10:51 PM
1999dodgeram's Avatar
1999dodgeram
Default 4wd slipping
i have a 99 dodge ram 1500 and the 4wd is kicking out, originally i had a broken vacuum line which was why it was kicking out so i temporarily taped it till i had money to replace the lines, then the 4wd stopped all together so i changed the 4wd vacuum lines and still nothing so i changed the 4wd vacuum actuator on the front diff and now i have 4wd but it slips, anyone have ne idea what this might be?
Old Jan 26, 2008 | 12:17 PM
zique's Avatar
zique
Default RE: 4wd slipping
Check to make sure you installed the shift fork in the right direction on your actuator. Did it work immediately after replacing the CAD or did it take a while before it started slipping again? Also, clarify what you mean by "slip"
Old Jan 26, 2008 | 05:21 PM
1999dodgeram
yeah the shift fork is the right direction, i changed out the hole fork/actuator assembly and the 4wd worked right away but when i drive it willkick out of 4wd and then kick back in
Old Jan 26, 2008 | 06:37 PM
zique's Avatar
zique
Check your linkage on your t-case and make sure it is set-up correctly. Maybe it's not engaging all the way.
Old Jan 27, 2008 | 01:57 AM
1999dodgeram
i dont think that would be it because when the vacuum line broke if i put it in 4low then i would get the low gearing in 2wd and it wouldnt slip, but ill take a look maybe something moved from it kicking in and out when i had the line taped
Old Jan 27, 2008 | 11:00 PM
1999dodgeram
yeah i checked the transfer case linkage and it wasnt that. i think ill try getting rid of the vacuum actuator and get a posi lock instead and hopefully that will fix it
Old Jan 28, 2008 | 12:00 AM
ezstiles's Avatar
ezstiles
I would look at yourCAD unit, take it off and see if the splines on the intermediate shaft are worn, I had this same problem, the shift collar kep't slipping when in 4*4, also if thats not it. I would check your spider gears in your front diff. If there is a broken tooth on the spider gears it will act like its comimg in and out of 4 wheel drive.
