dropping bearings
Old Jan 26, 2008 | 03:25 PM
mud_hound's Avatar
mud_hound
Default dropping bearings
droppin wheel bearin every 4 to 6 months what can i do so i wont have to replace them so often would a hub convertion help or can a upgrade to a heavyer duty hub and bearin
Old Jan 26, 2008 | 03:49 PM
TheForce55555's Avatar
TheForce55555
Default RE: dropping bearings
what size tires are you runnin???????. And also are you buying wheel bearings from advanced or pepboys???
Old Jan 26, 2008 | 03:52 PM
mud_hound's Avatar
mud_hound
im running 37s im not sure what type of bearings r in it last time it locked up at a dealership so i just let them replace them
Old Jan 26, 2008 | 03:59 PM
TheForce55555
I would say the 37's are the problem, probably gonna have to get the dana 60 axle if you want bearings to last more than 4-6 months
Old Jan 26, 2008 | 04:05 PM
mud_hound's Avatar
mud_hound
thats what i was afraid of that could convertin the hubs to a full floatin assembly help at all
Old Jan 26, 2008 | 04:09 PM
TheForce55555
Is that possible??
i dont think you can full float a front axle
Old Jan 26, 2008 | 04:24 PM
mud_hound's Avatar
mud_hound
so what could i get a axle off a 25 or 3500 and make it work
Old Jan 26, 2008 | 04:28 PM
TheForce55555
Yes i think it would work, im no expert, let some of the techs chime on this later and they will give you a definite answer, all i know that 3/4 tons have 8 lug wheels, which could be a problem
Old Jan 27, 2008 | 02:02 AM
rabbler's Avatar
rabbler
37 is too big for the stock axle. Especially if you work it hard.
Your rims probably don't have enough offset too. Do your tires stick out past the fenders a lot?
That places too much stress on the outer wheel bearing. that's probably why you chew 'em up so bad.
stuff a 2500 axle in there
Old Jan 29, 2008 | 04:10 AM
mud_hound's Avatar
mud_hound
i was considerin puttin 2500 axles with 4.56 gearsunder it im not sure what the offset is they r 15x12 rims and there out there pretty far no flares could cover them
