Door mounted rear view mirrors that won't stay put.
Old Dec 12, 2004 | 05:50 AM
Leonard's Avatar
Leonard
Default Door mounted rear view mirrors that won't stay put.
My passenger side one is fine but the drivers side swivels back at highway speeds.
How is the best way to fix this?
A friend said he had his done under a recall years ago.
They replaced them with the chrome ones.
Old Dec 12, 2004 | 01:15 PM
Snafu's Avatar
Snafu
Default RE: Door mounted rear view mirrors that won't stay put.
There are 4 bolts that hold the mirror clamp onto the mounting bracket. The clamp holds the round shaft on the mirror to the mounting bracket. Unfortunately, the bracket is aluminum and the threads strip, causing the mirror to fold back at speed. Take the mirror off, then drill and helicoil the aluminum mounting bracket for 1/4"-20 UNC bolts.
Old Dec 25, 2004 | 07:46 PM
rob[GL]'s Avatar
rob[GL]
Or you can do what I did, put nailpolish inside the threads and tighten all four bolts one turn at a time. Now my mirror is so tight I almost cannot adjust it.
