doing plenum soon what do i need and expect?
yes ive read up all the threads but wanna make sure i dont miss something would have posted in silvers thread but didnt wanna steal the thread..... heres what i wanna do.... first off the plenum repair kit also ima get 180 tsta and do the fastman 50mm tb while im in there is there any little thing i sould do whil i got my hands dirrrrty im already spending a lil chunk a change so i wanna do it right lil thing like new plugs and other **** like that i can do later cause i plan a reg tune soon also ill just a thing or two here and there so if yall got some advise pls help me out ill keep my eyes on silvers posts and i just wanna start ordering soon the ping drives me nutz......j
RE: doing plenum soon what do i need and expect?
Ford motorsport 24lb/hr injectors. See sig for part number. if you are putting on the fastman the 24 lb/hr injectors will compliment the higher airflow with the extra fuel they provide. And go with an open element air filter. If you are getting more air in the engine, you will get more power with more fuel as well. Then if you get a Mopar PCM or B&G...you will really see a difference with the injectors.
Getting the heat shield tape for your fuel rail would be cool to do....as well as some orange paint!
edit. While everything is off...adding an underdrive crank pulley will free up some HP. I am gonna do pulleys, electric fan, 4 degree advance timing chain,and a fastman with my plenum install. Like you, I want to get as much done as i can with everything off.
BTW, where can i get a hughes plenum kit? I have been searching and i can't find it.
http://www.hughesengines.com/partDet...p?partID=11698
http://www.hughesengines.com/partDet...p?partID=11584
whats the injectors run ? or even the pcm ? just curious im not working with a ton a money so i figued the best bang for my buck would be fastmans 5mm and my plenum kit little stuff can come a lil down the road.... ya feel me....not literally..... also what kinda discount does fastman give on the tb's if ur part of this forum......j
