4X4 PROBLEMS!!!
Old Jan 30, 2008 | 05:36 PM
MECHMAN's Avatar
MECHMAN
Default 4X4 PROBLEMS!!!
I have a 1995 dodge ram 5.9 4X4 with 150,000 miles. I just bought this truck recetly. My problem is that when I engauge the 4X4 it takes forever for it to kick in and out. Anyone have any ideas on what usually causes this. It's kind of a hassle when it's not there when I need it. Your info is valued thankx.
Old Jan 30, 2008 | 06:16 PM
Houston4x4's Avatar
Houston4x4
Default RE: 4X4 PROBLEMS!!!
Does it take forever when you shift into 4H while in motion? Or only when you are sitting still?
Old Jan 30, 2008 | 06:40 PM
seawind3000's Avatar
seawind3000
You have a problem with the vacuum shifter on the front axle, you can replace it with an after market cable shifter or buy a new vacuum unit.
Mike
Old Jan 30, 2008 | 07:30 PM
zique's Avatar
zique
Old Jan 30, 2008 | 11:57 PM
MECHMAN's Avatar
MECHMAN
It doen't kick in while moving or standing sill or in drive neutral and reverse.
What are the pros and cons of the cable shifter vs. the vacuum shifter
Old Jan 31, 2008 | 12:08 AM
dhvaughan's Avatar
dhvaughan
http://www.dodgeram.org/tech/repair/..._engagment.htm
https://dodgeforum.com/m_718119/tm.htm
cad
pros - already installed. probably can be fixed
cons - doens't work.
posilok
pros - simple, dependable.
cons - costs $175.
