Surging and noticeable engine misfire
Old Feb 1, 2008 | 11:09 AM
firerescue251's Avatar
firerescue251
Default Surging and noticeable engine misfire
I've got a little problem on my hands....
The other day driving to work i noticed my truck starting to misfire really bad(which is really weird because the day prior to that the plugs, wires, distributor cap, rotor and pcv valve were replaced and the truck ran like brand new). Anyway i continued driving and only while at idle did the truck continue to have a very bad misfire or so it seemed. So i looked at my gauges...the battery voltage was fluctuating a lot and the truck started sucking a lot of gas. The truck started throwing codes. One was about insufficient coolant temperature and the other one was about 02 sensor bank 1 sensor 3 no activity detected. I also started smelling raw fuel..... I have no clue on where to start and was hoping i could get some suggestions.....
Old Feb 1, 2008 | 12:40 PM
padodgeram's Avatar
padodgeram
Default RE: Surging and noticeable engine misfire
change the 02 sensor..
Old Feb 1, 2008 | 01:31 PM
firerescue251
sorry i didnt put that in there........yeah i do that sometimes.....02 sensors are brand new......there is no bank 1 sensor 3. the truck only has 2 sensors one before the cat and 1 after
Old Feb 1, 2008 | 02:35 PM
05DodgeRamHemi's Avatar
05DodgeRamHemi
Hmm...sounds almost exact of my situation. I had the same misfiring going on and it would hardly move. The fuel smelled really rich, like a snowmobile, and at times was black. I too had just gotten a complete tune-up like you and that didn't do anything. I just got my truck back, he replaced both 02 sensors, and yeah, after all that heartache, she finally runs right now...FINALLY.
Old Feb 1, 2008 | 03:05 PM
firerescue251
its really startin to make me mad........it does it every now and then. It started causin me problems when i ran through a giant mud pit....it started throwin the o2 sensor codes........and started smellin like raw fuel. Cat was changed and one o2 sensor was changed.....my buddy said it could be the other o2 sensor or a fuel system problem
Old Feb 4, 2008 | 02:14 PM
firerescue251
no suggestions.......
