Ignition problems
Old Feb 1, 2008 | 03:29 PM
WillTX's Avatar
WillTX
Default Ignition problems
I have a 98 1500 2 wheel drive quadcab. i know im getting fuel but no spark. i replaced the spark plugs, wire, cap and rotor last summer and it has ran fine till the other mornin. i pulled off the distributor cap and noticed that it wasnt seated down right. cleaned the cap and rotor replaced but still the same. couldnt check the plugs due to the weather. stumped on this.
Old Feb 1, 2008 | 03:32 PM
Ram2K1's Avatar
Ram2K1
Default RE: Ignition problems
Could be the ignition coil...or the actual distributor (not cap). I'm not really sure...
Old Feb 1, 2008 | 03:48 PM
WillTX's Avatar
WillTX
my truck has high mileage, is it worth replacing the coil even if theres nothing wrong with it?
Old Feb 1, 2008 | 04:00 PM
Ram2K1's Avatar
Ram2K1
It's never worth replacing something if nothing's wrong with it... Take it to Autozone or somewhere that runs diagnostics for free...see if it throws any codes.
Old Feb 1, 2008 | 04:14 PM
WillTX's Avatar
WillTX
will do, if i can find a ride in the mean time.
Old Feb 1, 2008 | 09:10 PM
dhvaughan's Avatar
dhvaughan
a coil is not too expensive, about $40. you should be able to test the coil using a volt meter and an ohm meter. there should be a test procedure in the haynes manual and/or the service manual in the merry christmas thread. test for 12 volts coming in. then disconnect everything and ohm out the windings.
uhm.. kinda hard to take it to az to test codes when it wont run.
Old Feb 2, 2008 | 10:49 AM
WillTX's Avatar
WillTX
i got it running. all it need ed was a new cap and rotor. the wierd thing is that when i went to Auto Zone the tested my coil and the secondary was good but the primary came up 0.00 same with a new one. gusse the guy was testing it wrong, but anyways it runs and thats all i need.
