A not so usual lift question
Old Feb 3, 2008 | 12:05 AM
vz893's Avatar
vz893
Default A not so usual lift question
Ok, so I want coilover in the front of my 2wd 1500 but I'm not quite ready to fork out the $$$$. In the mean time I need/want a lift in the front to clear 31's in the front at full compression. I know that the stock UCA maxes out at about 2" of lift. I'm on a budget so longer UCA are a no no. Now on to my question. I planned on using a 1.5" coil spacer along with a 1.5" upper ball joint spacer. I know that the coil spacer is ok with the stock uca, but would the ball joint spacer go past what the uca is capable off? If you have no idea what I mean by a bj spacer, it's basically a block of aluminum between the uca and the upper bj.
Old Feb 3, 2008 | 12:48 PM
Dontdodgeitramit's Avatar
Dontdodgeitramit
Default RE: A not so usual lift question
Possibly... I would check with a specialist or with the manufacturer. Depending on where u are this is usally a fab shop near by that does lifts. I get expert opinion not to be mean but u need to be able to ask a creditble source.
