Old Aug 7, 2015, 12:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine
Print Wikipost
Kegger Intake Mod DIY
Old Feb 18, 2008 | 11:41 PM
  #91
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Kegger Intake Mod DIY
From what I understand, the 5.2 just doesn't have the cubes to cut them down that much. They say you'll lose low end. Try it and let us know.
Old Feb 19, 2008 | 09:30 AM
  #92
Silver_Dodge
Got an interesting update for you all. I'm now getting 12 mpg highway, 10-11 city. Might not sound great to some, but that's ok with me (given the mods I have). Here's the interesting part. Last time I got that kind of mileage was before my plenum went bad, right after I installed the B&G (was getting 14 highway, 12 city before the B&G). The kicker is that I was running 33" tires with my 4.10's at that time. Now i'm running 35's, and getting the same mpg. You would expect a mpg decline when moving up from 33's to 35's. This tells me that since the intake mod is the only thing that has changed since back when i was getting that mpg with 33's, the the intake mod has resulted in an overall increase in mpg.
Old Feb 19, 2008 | 10:25 AM
  #93
padodgeram's Avatar
padodgeram
time to upgrade the ingition there silver
Old Feb 19, 2008 | 02:56 PM
  #94
nolazach's Avatar
nolazach
glad to hear that. I just put mine in. I have been taking my sweet time with this. I stopped to paint it black. Then spent a while doing other things. I'm about to head back in there and put all the accesories and fan back on. Hope to have it on the road in a day or two.
I took lots of pics and will post them, I just wanted to finish up first.
Thanks for the DIY and the updates Silver, I check them daily and it really has helped alot to have this thread.
Old Feb 19, 2008 | 03:33 PM
  #95
Silver_Dodge
Good, that's why I wrote it. Glad to see it was helpful.
Old Mar 6, 2008 | 12:16 AM
  #96
CPTAFW163's Avatar
CPTAFW163
^^ That was harsh. Indy and i are part of the "Dodge Forum Fire Department" and comments like that will incurr the same Karma as we got.
But seriously. I am sure that silver's mod is better than how it was before.
Old May 11, 2008 | 12:55 AM
  #97
greg_glider's Avatar
greg_glider
Thanks for the write-up guys, especially Silver for all the helpful info! I do have a spare intake that I will be working on soon, I just had to do someresearch on how much of the runners I will cut off. I have also seen write up on other forums, but this one is by far the best!
Once I finish modifying my intake, I too will post pics.
thanks again!
Greg
Old Jun 26, 2008 | 12:42 AM
  #98
Ditch Bitch's Avatar
Ditch Bitch
i dunno what you used to get a clean cut... i tired a dremel with cut off wheels. After several broke wheels, i broke out my 4.5" angle grinder and went to town... made a big mess haha.
I wont know if it made a difference on my 360, bought the truck with a blown motor and while it was a part i figured id give it a shot.
Almost done, got them trimmed down, now just need to clean them up.
Old Jun 26, 2008 | 10:06 AM
  #99
Silver_Dodge
I used some aluminum cutting bits hooked to a drill to smooth out the cuts. Worked great. In post #2, there is a picture of it attached to the end of my drill. Also used a really stiff brass wheel on a drill too (last picture in post # 4). It removes the burrs very nicely.
Old Jun 26, 2008 | 10:28 AM
  #100
steve05ram360's Avatar
steve05ram360
I used a rotozip with a cutoff wheel from sears, worked great. once you get the hang of it, you will break fewer cutoff wheels.
I used the dremel buffing/sanding *****, they came in 120 & 220 grit and worked perfect. plan on buying a bunch though as they dont last long.
