Question about Injectors
Old Feb 6, 2008 | 12:13 PM
venado's Avatar
venado
Default Question about Injectors
I will like to know if an injector can be fixed or what part should be busted in orderto be replaced ?
Which is the price of an injector & who could have good (on-line) prices on injectors ?
Old Feb 6, 2008 | 12:17 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Question about Injectors
Is your injector in question broken?
Old Feb 6, 2008 | 12:18 PM
Parts/Service's Avatar
Parts/Service
I wouldn't think that an injector could be fixed if any part is broken, not 100% sure though. The factory injectors are about $70.00 each and the part number that you need is 53030778. The injectors are the same for a 5.2L and a 5.9L...
Old Feb 6, 2008 | 01:27 PM
venado's Avatar
venado
ORIGINAL: VWandDodge
Not Shure.
Im having some problems with my truck i dont know if an injector is broken or they just need to be cleaned but im preparing my self for the worst in case they tell me i have 2 or 3 busted injectors [sm=bicker.gif]....
My truck was working fine & suddenly the motor started working like if a spark plug was busted i checked them all and they just look fine but black smoke is going out the muffler and smells like un burned gas .
Old Feb 6, 2008 | 01:34 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
How can you be breaking plugs and injectors? I think you're reading more into this than there is. First, do a search for "cleaning" or even "sonic cleaner" in this forum. Injectors don't break unless you crawl under the hood and whack them with a hammer. You have other issues to address. First, how many miles on the engine? When is the last time the oil was changed (with the filter); the air filter; O2 sensors, etc. Are you still running the original converter? Is your truck throwing any codes?
Look at things like that first.
Old Feb 6, 2008 | 02:22 PM
Tarner's Avatar
Tarner
Rock Auto. Best place I've found for OEM part on the net. Don't start buying parts till you know whats wrong. You'll go broke in a hurry trying to fix things that aren't broke.
