Plug Heat Shield
Old Dec 14, 2004 | 03:05 PM
sail247's Avatar
sail247
Default Plug Heat Shield
When removing a spark plug, does the heat shield remain on the block or does the heat shield come off first and then the plug?
Old Dec 14, 2004 | 03:54 PM
GMsucks's Avatar
GMsucks
Default RE: Plug Heat Shield
Heat shield stays.
Blow some compressed air at the base of the spark plug after you take the wire off and before you remove the plug.
Prevents **** from falling into the cylinder.
