DTC code of P0740 and p0307
Old Feb 6, 2008 | 04:34 PM
firedog's Avatar
firedog
Default DTC code of P0740 and p0307
I have a 98 dodge ram 1500 4x4 5.2. The check engine light is on. I had it read, and it came up with P0740-Torque Convertor Clutch Circuit Malfunction. How do you fix this?
It also came up with the codes p307 and the other ones for random cyclinder misfire. I changed the plugs wire and cap within 20k miles. I have autolite platinum plugs and autolite wires. What would cause the cylinders to miss fire.
Also there are times when coming to a stop the truck will cut off. It always starts back up.
Thanks in advance.
Old Feb 7, 2008 | 08:28 AM
firedog's Avatar
firedog
Default RE: DTC code of P0740 and p0307
anyone??
Old Feb 7, 2008 | 02:20 PM
jasonw's Avatar
jasonw
Site Moderator
As far as the second question goes, did you route the wires properly? The wires for cylinders 5 and 7, I believe, need to be wired differently otherwise our Magnum engines will misfire. Do a search on the forums here for more info on that, its been discussed before.
As far as the first problem, I would advise you to take it to a transmission expert.
