How can i check my alternators amperage?
Old Feb 6, 2008 | 11:12 PM
terranova's Avatar
terranova
Default How can i check my alternators amperage?
Could someone tell me how i can check the amperage of my alternator for my pickup? 1998 1500 Laramie SLT 5.9L.
Old Feb 7, 2008 | 12:32 AM
terranova's Avatar
terranova
Default RE: How can i check my alternators amperage?
bump
Old Feb 7, 2008 | 02:19 AM
01Tx1500's Avatar
01Tx1500
You can take it to an auto store like autozone or O'riellys and have them check it for exact amps it is putting out right now. Otherwise being a 98 I would find out if you have the tow package, if you do haveitthen you have a 136amp alternator, ifyou dont have itthen you have a 117amp alternator.
Old Feb 7, 2008 | 06:48 AM
HankL's Avatar
HankL
old post:
Jonathan B
Subject: Re:Will high amp 53008651 alternator bolt on in place of
smaller ones?
Hank, I have swapped out the two different alternators
a few times without any problem. The one that's on the
motor right now is a 53027913, ans the spare in the
tool box is a 53008651. I don't even remember what
came stock on my truck.
--- Henry wrote:
> Will the larger 120 amp rated Ram pickup alternator
> bolt on in place of the
> lower amp rated alternators on the gasoline V8s ?
> Anyone do this swap already?
> On my 1995 alternator the nameplate says:
> 53008647
> 121000-3470 12V
> Family 90HS
> Denso
> Made in Japan 70113
> On page 8B-10 on the 1995 FSM it says the
> Denso 53008651 is rated 120 amps and has 7 grooves,
> whereas the 53008647 of Family 90HS is only rated 90
> amps.
> It also says the diesel has 8 grooves and is
> 56027221
Hank , I think you brought this up a few weeks ago. It piqued my
curiousity. The '98 Jeep Grand Cherokee 5.9V8's did come with a 150 amp
alternator from the factory. I'm guessing it had largely to do with the
electric fan that they also came with. I just picked one
up to see if it would work on my Dakota. The answer is, no for any vehicle
before 1998. Different
connectors than on my '95. I thought there had been a switch in terms of
connectors
at some point and it turns out that it was in '98 and up. The part number
for anyone that is curious is 56041394AA for this piece.
