Pinging with new pluenum? 89octane
Old Feb 7, 2008 | 03:32 PM
Dontdodgeitramit's Avatar
Dontdodgeitramit
Default Pinging with new pluenum? 89octane
Pings like before I changed the pleunum.. Its only about 2mo old.. any ideas?
Old Feb 7, 2008 | 03:36 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Pinging with new pluenum? 89octane
Any new oil leaks when you look down inside?
Old Feb 7, 2008 | 03:52 PM
TheForce55555's Avatar
TheForce55555
Even if you did replace it, it still can be leaking. Depends on what parts you used. If you just replaced the gasket then it will leak again
Old Feb 7, 2008 | 06:09 PM
techshooter02's Avatar
techshooter02
what else should have been done when replacing the plenum gasket?
Old Feb 7, 2008 | 11:51 PM
Dontdodgeitramit
Which parts should I have used? Rtv black high temp.. new gasket and a in/lb torque wrench? Could bad gas cause it? It jus started today. an it kinda boggs out.. I will try some heat and new gas.. if not then I might need some ideas to fix the problem.
Old Feb 8, 2008 | 12:06 AM
dhvaughan's Avatar
dhvaughan
the bogging sounds like a vacuum leak.
if its been running fine for 2 months,and just started pinging yesterday, don't panic.
could be some bad gas.
could be a broken, cracked, or rotted vacuum line, including all the way down to the t-case. sometimes its easier just to temporarily plug them all at the manifold, and do a short test drive. it its ok, then add them back one at a time until you find it.
could be carbon buildup.
