2 plug wire ?s
Old Feb 10, 2008 | 02:06 PM
hometheaterman's Avatar
hometheaterman
Default 2 plug wire ?s
I put my new plug wires on today and it was a long painful experience. Didn't go as smoothly this time as it did last time. The first question is they touch the valve covers is this okay? I wanted to make sure the covers won't get hot enough to melt them.
The second is when cutting zip ties with a knife the knife slipped 2 times and poked a small hole in the shielding on the cylinder 8 wire. The second time it created a slit in the shielding on the coil wire. I put wire loom around this to cover up the hole and slit in the shielding. Is it okay or do I need to replace these wires? I really hope it's okay as I don't want to spend another $80 on wires.
Old Feb 10, 2008 | 03:26 PM
Ram2K1's Avatar
Ram2K1
Default RE: 2 plug wire ?s
It really depends on the integrity of the wire inside. If you just damaged the casing, you can just wrap it good with some good electrical tape and be fine(I have done this...I damaged the casing putting the wire into the loom). But, as long as you didn't actually jeopardize the integrity of the conductor wire itself, you'll be okay. Just check em out real good and make sure...and see how it runs, check for any arcing, etc.
Old Feb 10, 2008 | 04:22 PM
hometheaterman
Seems to run okay so far and it is looking okay from putting one of those pins on there that show when it's firing. I'm hoping it will be okay. Thanks.
Old Feb 10, 2008 | 04:35 PM
aim4squirrels's Avatar
aim4squirrels
Next time cut the zip ties with a small pair of wire cutters.
Old Feb 10, 2008 | 04:38 PM
TheForce55555's Avatar
TheForce55555
+1, never slice and dice with a blade, near vaccum lines or plug wires, plus you could lose a fingertip really fast if your not paying attention
Old Feb 10, 2008 | 04:51 PM
hometheaterman
I know I just was too lazy to go get wire cutters out of the tool box.
hometheaterman
Next time I guess I wont have to be lazy and go get them.
