cracked brakes
Old Feb 12, 2008 | 06:35 PM
Mknabb1111's Avatar
Mknabb1111
Default RE: cracked brakes
You will have to bleed the front brakes if you replace the calipers, but not the back if you do not work on them.
Old Feb 12, 2008 | 08:23 PM
charlie1935's Avatar
charlie1935
ORIGINAL: rango726
my brakes were grinding so i bought all new pads to find only the passenger side rear were grinding and all other pads were in excellant shape better than the ones i bought. it looked like the dealer never changed those brakes and they were all brittle and falling apart.let me know if the crack is an indicator to something.
I would say the passenger side caliper was sticking. The cracked lining on the pads leads me to believe they had been over heated. I would replace both calipers and pads and have the rotors resurfaced or replaced.
Old Feb 13, 2008 | 12:50 AM
CSCustomCars's Avatar
CSCustomCars
ORIGINAL: hometheaterman
Are the Cardone calipers any good? I can get them cheap from Fishers. Seems like that or Bendix from Summit are my only options around here.
I had cardone calipers on my sunfire. They did the job just fine. They are fine for replacements. Go with them.
