305/70/16 on 2000 1500
Old Dec 16, 2004 | 04:26 PM
Bender's Avatar
Bender
Default 305/70/16 on 2000 1500
I need new tires, and was going to go with 285/75/16's and was just wondering if anyone ever ran 305/70/16's on a stock suspension 2000 1500?
Old Dec 16, 2004 | 05:36 PM
doziersdodge's Avatar
doziersdodge
Default RE: 305/70/16 on 2000 1500
You might can do it with wider wheels. I had 33x12.5x15 on a stock 97. I also had 15x10 wheels. I have a 2 inch lift on there now with 305/70/16's. I also have 16x8 rims. On tight turns, with a bump, they rub.
Old Dec 16, 2004 | 07:58 PM
Bender's Avatar
Bender
Thx, just found this iste, seems not a lot of difference between 285/75/16 and 305/70/16
http://www.eunos.com/tirecalc/
iste=Site
Old Dec 17, 2004 | 01:35 PM
steve05ram360's Avatar
steve05ram360
the diameter is the same, it's the width that causes the rubbing. With stock rims and lift you might have a problem.
Old Dec 17, 2004 | 02:51 PM
doziersdodge
Yea, diameter is same between the two sizes. 305 is 12 inches wide and 285 is 11.2 inches wide. That extra inch will cause the rubbing. I think 285's will fit. Try this link http://www.ntwonline.com/template.cfm?ID=8 at the NTWonline website. Check out the fitment guide.
Old Dec 17, 2004 | 02:55 PM
steve05ram360
Hey Bender another thing to remember is the gearing, I had mine swapped out to 4.11's ($1400)
Old Dec 17, 2004 | 07:16 PM
Bender's Avatar
Bender
Thx, I was thinking about a 2" block lift, and actually the 4.11 gears is also something I've been thinking about. Maybe this is the time to treat myself
Okay, maybe AFTER the holidays
