Wont start... Help....
Old Feb 14, 2008 | 09:34 PM
JCliffordd's Avatar
JCliffordd
Default Wont start... Help....
Ok so tonight my truck was fine i put gas in it (might be the gas) and it ran fine after and i shut it off a few times and started it back up but as i was leaving the parking lot and i went to go start it and it started ran really rough and then died, so i was like huh... tried it again same thing. Then the 3rd or 4th time i tried it giving it gas and everything it would just start up then die. Im thinking Fuel pump? Bad Gas?
Anyone have any ideas. And the Distributor is a bitch to get to, but my coil was fine.
At a lost please help me guys.
Thanks
-Jared
Old Feb 14, 2008 | 09:38 PM
JCliffordd's Avatar
JCliffordd
Default RE: Wont start... Help....
Also i couldnt hear the fuel pump click on but i wasnt sure if i could hear it or not being next to a road.
Old Feb 15, 2008 | 07:04 AM
JCliffordd's Avatar
JCliffordd
Anyone?
Old Feb 15, 2008 | 12:27 PM
citygasdude's Avatar
citygasdude
You could try spraying some carb cleaner down the throttle body and turn it over and see if it tries to start. If it doesnt I would pull one of the plugs and hook the wire up to it and have the plug electrode touching the exhaust manifold and have some one turn it over to see if you have a spark. Hope that helps
