New Ball Joints, Bearings, Etc
Old Feb 17, 2008 | 02:29 PM
CSCustomCars's Avatar
CSCustomCars
Default New Ball Joints, Bearings, Etc
Seeing as how I go to HVCC for auto tech, and I can get anything repaired on my truck for $15 and the cost of parts, I'm going to have my entire front end re-vamped. I've had this mysterious shake at 35, 60, & 65 mph, and having 137k+ on the clock, I think it's time. My steering is also starting to wander a bit, which leads me to believe, my mechanic was wrong about my ball joints, seeing as how my track bar is tight.
My plans are new upper and lower ball joints, both sides, and new wheel bearings. I was thinking about doing the tie rods too, but I'm not sure yet. I may replace the front shocks as well. I think my lower shock bolt on the driver's side is stripped out. I had it re-tourqed, and the shake got worse.
Is there anything else you guys would recommend doing while I'm in there?
And I'd like to use decent parts. I don't want to have to be replacing these things again for a long time. Any brands you would recommend? or should I get genuine Mopar parts?
Thanks guys.
Old Feb 17, 2008 | 02:47 PM
dhvaughan's Avatar
dhvaughan
Default RE: New Ball Joints, Bearings, Etc
if i could find someone to work on my truck for $15, i'd replace every blooming moving part in the front end, including gears in front and rear.
gears and install kit, seals, bearings, ball joints, u-joints, rotors, pads, track bar, tie rod ends, shocks. lets see, did i miss anything ?
spicer or moog. look for greasable versions of the parts.
Old Feb 17, 2008 | 05:18 PM
aim4squirrels's Avatar
aim4squirrels
Replace all the bushings while you're in there, and with poly's not the standard rubber.
Old Feb 17, 2008 | 07:39 PM
blkbaretta's Avatar
blkbaretta
ORIGINAL: dhvaughan
+1000, but I guess I do learn a lot from doing things on my own. Oh well, it would save lots of time if someone else did it; I'm kinda slow when it comes to workin' on vehicles.
Old Feb 18, 2008 | 12:50 AM
CSCustomCars
ORIGINAL: dhvaughan
Well, I have part of that list done already... Seals are new, u-Joints are new, Rotors just turned, and new pads. I'm really loveing going to school here. I love getting my truck fixed while I'm in class for $15.
As for gears, there's nothign wrong with them, so I'm not gonna replace them.
I was thinking Moog, but i also saw TRW. Anyone know anything about TRW stuff?
Old Feb 18, 2008 | 01:18 AM
hometheaterman's Avatar
hometheaterman
I'd get moog or spicer also. A buddy that used to work at Advance told me not to get TRW stuff but I don't know why. I used their idler arm on a old truck but thats all I've used from them.
