How do i disconnect this connector
Old Feb 18, 2008 | 04:32 PM
CPTAFW163's Avatar
CPTAFW163
Default How do i disconnect this connector
It goes along the top of the tranny. I have tried and tried, i don't know how to get this off. The plastic has hardened over the years and it won't budge.
https://dodgeforum.com/albumtn.aspx?...l831301231.jpg
The pic won't embedd in the post so there is the link ^^
Thanks
Old Feb 18, 2008 | 05:29 PM
Tarner's Avatar
Tarner
Default RE: How do i disconnect this connector
This is what I get when I try to look at the pic. I think something is wrong with the link...
ÿØÿà �JFIF��H�H��ÿÛ�C�     $.' ",#(7),01444'9=82<.342ÿÛ�C  2!!222222222222222222222222222222222222222222222 22222ÿÀ��Z�x"�ÿÄ��� �������� ÿÄ�µ���}�!1AQa "q2‘¡#B±ÃRÑð$3br‚ %&'()*456789:CDEFGHIJSTUVWXYZcdefghijstuv wxyzƒ„…†‡ˆ‰Š’“â€â€¢â€“—˜™š ¢£¤¥¦§¨©ª²³´µ¶·¸¹ºÂÃÄÅÆÇÈ ÉÊÒÓÔÕÖרÙÚáâãäåæçèéêñòóô õö÷øùúÿÄ��ï¿½ï¿½ï¿½ï¿½ï¿½ï ¿½ ÿÄ�µ��w�!1AQaq" 2ÂB‘¡±à #3RðbrÑ $4á%ñ&'()*56789:CDEFGHIJSTUVWXYZcdefghi jstuvwxyz‚ƒ„…†‡ˆ‰Š’“â€â€¢â€“†”˜™š¢£¤¥¦§¨©ª²³´µ¶·¸¹ºÂÃÄ ÅÆÇÈÉÊÒÓÔÕÖרÙÚâãäåæçèéêò óôõö÷øùúÿÚ� ��?�æÃ*%;·2sÃ*WQåûnãÂ@¾ù¬è « 2:zÔ]¬…ÈÂçÞµG Ã=ÃÂ*Ã’>1»Ò†>LÇ9ÈêÃ5–'Û ##'«Ÿi óËúŠfNEéeyÃ*ßCKÃ’eV;€Èã½PK§ *¨úæ®Ãp#Fs‘€Þâ€X‡+³sC±¼×M¨¬q ƘVç ¯óÂ*ë »[}vk(¢Ž3 jBŽà “×òª~¸1éÃà n$ïÃeÃ\C¤xªêéØ ,*Û'5ËmnzðnÉ3³Õtk}NÅâIôì2Ÿâ€Å¸Q\ ‡†Â¸/xSkS¯´[ òaQÊÄûÃßSu‡½G©Å&Ö úƒÃ÷Â*u)•çé_1è^?ÔtÛxÂ*nâ„¢bA'¨ìÞ 񥖱d›'O7øâ€Â·4Ôˆq;Â¥}š£ØnEHnà “i9ÕdXµ‘EdiÚ«ÃÃ$o B‡¿z( ÅÅÙŸ5ë[LñFÖ“=qÖ¯[KæÛåHéÉôª²þöÒ ÃÅ’ÂÃê‘ì§Å“E!ÇOº}+HÅ“Uµ6‘w¿qôà µÂ«ä³:€ÙQӫ˨ ‘Œà š·§$ º�`8r3Vs4‹>vö ‘Œóž1RM.Ôã=ºVzà ù$õçÞ¯K©Ã*dA³ƒ‚yÃ…&Âæz¥•Úà ™Ã˜â€¡r…QòúÃ*«øfÃÄP£_4«rI*èÛO=«G1 ºÂ®Ã¹Ã€@F�É•tvÃ.ÂrÓÜHCÂ=+Å¡O¡Ã*Q‡ SCLðf‘áöûR@eËœËYÛq_§aVîm¤ñ=«Ú»˜ì Û†aÕþžÔëV—Y 5ÊÃ*€qSëZJÿ�c €mAÛTÅ¡kó<[Æ? çÒw\iÃ*æÛc8=V¼â?Ã* "ï1»Ã*÷ôÖ§¯$ñËgm¹nVBV?ñ>¼¯à „~Q´n¢?2•tüzb“ò);üF~‹ñST± øóÔà ×]iñGM™ÇœÃ}ExóÇi,ûmî°8*ÜVÅ xgQ¹„É »8×…;à žÇºXøßEËœe.ÂsÃáËáÂa—⠀¹)¸ïŠ*½¡ݔ-µÚ‹y#fà ãn:gšžÎÆk¤f!>ÌÜ3HáFG¦Msi *XB ¦Ã§û«Wì5¯<2I¨5ãÈÂ*ˆà Â[ß$ñ[¦–§£ttNÚ¸V¹ì<áÃFúmñL¤qÉŽÉ"â €œÃ¼Ã«>?à æËÃâ€ïNÃ!?Ã’ÂÄB“²Ã¦ÃÇ-“ þ"Ÿ´]Å’]Ë–67 |‘ÜC$aŽrêGJë'µòÂ* @xZÃÑ‚Â*4Ñp‡!ÈÚj—mÂ%¼| ÞŸOJ5/ßO,K-¬j!nT‚A#ÖªÜ]Ãm¯’P¬0:cÇáXú¦¡nK4Bÿ�6\ó“šÃà †'B©#Û<+ã+-jßj˜à š 7@ÃŒ3õ¢«x—Än Â*É‚ÙAÃ2õ¡ì=ëÆQn•:çs Ã¥Â*+ ÛÃFëìºÂÙ‘…i@U·Ö³p} cUuG£iÂÓ-¤· •e3ÉÇZšó§SP׎÷öHÃ*·þùÎ+kO°òtà «$<ÂǯäŒ)8©¤‰½Î?i–bhŠÚF%á ¢•üGq\œÚ/ˆü~ú—‡îöÓ ËiÃ�v�õü+¹ñlv“ê,²A ì¨PHÂ*r¦ÚaÄS][8û¾Tìåœ~â€ÃšLÅ¡V6´/ˆºV°¦9ÔZ]t’ N>Þ´W–øŸDynæ+‰f¹‘°Q’�ë µ“‚-O¹¶›¦Àp‘#ȧ†ûÇãÒªA`L%m÷œ` ¨Ö½ãáüK0’ÞV\ ŠÆÔ¼/¨YÄ¡bó¶’O—ñÌq䤐1)’ÙÜE×Ë/ócëVlì´ýEZ;‰$YÀèçܲ´»ºº[hà ÂÃŒNÄs]Wü+›YmëºÜÿ�~&Æ)·`WzW„ôÓ§xËœ) l£FØjõ6W{#ÄËáñëVò Ç™7ù`2Â×é]µ“f2eJõã™ëWGÅ“kæÂËľf¡o+EqÂÉŠ¾pr?*[ÃÃköÃ8ɆHó(ôç¥z n›¨™ÂŸáÆEq¾*ñUŽ•âX ¶Ž!m,jÃ’à Æà à >ÂED·-?tåå2¥»Is Ñ=©æ7äû~™¯›ýZÊÙ!]²J¨Â#ŸJî®tX<–õ'ô®‡L˜’¯ò‚Ë …$dŸì=ë#ÅòÃ.Å“påÈP§&´t)Dºm¼¥à ¶yˆ9þ7?ÃUÓdÃõ«)µ îÚ<¤²! ƒ´†þ•à º×‡uÂÿ�âge<$ñ½à þ=+èI'Lmß‚x¹Ãi[[‹»0 ÊW Ž2¶)ÕvÔPW<‹á¾¼ÿ�ÙïdÃ|‘8Ù»¦ Óë^³áïécÆWž$龄ceÇFn§ò�W!Æ’e§ø ªæH¢ÂöîÅ’/ÂvÅ¡j´ó\%Å“dÇ…i�=�éúÿ�*7ÂÅÖÅ Ûiö³;"•[VHpWýÂ*lÂ*–ŠDÃS³ü+?RÕ¢û]¹€å’Ä UÉvÃ¥TÂTîʃøVZ=Z,ñ_ˆ:^£áÃiµÂâv†šWódÂI 1<ñèx®ÂÃ"ÖmV·ÙrG<Âqï]uê++ÂÓ"¼›Æ¥·Œ4‡Â&y0ÃÚXdpqÖ “Œ[Õ W=nà ¢PÀ¯f&ŠÉ±fm‰ñÉ÷4Szh3ÿÙ
Old Feb 18, 2008 | 05:31 PM
Tarner's Avatar
Tarner
Ok got it to work now.
Old Feb 18, 2008 | 05:32 PM
Tarner's Avatar
Tarner
2
Old Feb 18, 2008 | 05:33 PM
Tarner's Avatar
Tarner
It looks like it melted together.[:@]
Old Feb 18, 2008 | 05:35 PM
pcfixerpro's Avatar
pcfixerpro
That looks like the same connector on the... black box w/ the fuses in the engine compartment. mine is an o1, and it has that connector running down the positive battery cable lead. When I was messing with my starter, i undid that plug (my gray one, not the tranny). I had to push down on the tab, and push teh entire connector together hard, then kinda pull apart while still pressing down. Was a PITA, but im sure you'll get it eventually. No tips on getting it off, but dont break it . I busted the connector that goes to my starter (its different than yours). Mine is held on by silicone and zipties because the attaching clip broke off. Oh well, dodge wants 80 for a new battery cable and can't guarentee that wire + connector comes with it.
- - - EDIT
Ah, I started to post before you got the second pic up. Um... Yea that is a different connector. Sorry man scratch what I said before.
Old Feb 18, 2008 | 06:40 PM
CPTAFW163's Avatar
CPTAFW163
I am gonna give it another try, if not i will just splice the wires together. No biggie
Old Jan 27, 2011 | 07:01 AM
UnregisteredUser's Avatar
UnregisteredUser
I can't see the image, something wrong with the way it's being served and I'm not really inclined to fool around with it... so what's it leading to?
Until the answer comes along: Frequently, old plastics tend to end up fused together with whatever gunk was carried into them along with splashed water, atmospheric moisture, and dead faeries. Most often, a good spritz of sensor safe cleaner will flush a lot of that gunk out, and following it with a silicone lubricant of some sort will make it possible to finesse the pieces apart without breaking things. Patience is required, but in most cases it's doable.
And if it ain't, then as VeeDub would say, hit it with an ax.
Old Jan 27, 2011 | 09:08 AM
dipsherry's Avatar
dipsherry
page not found...sorry cant help ;-P
Old Jan 27, 2011 | 10:28 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Do you guys not realize this thread is almost 3 years old????
