Crank sensor swap
Old Feb 18, 2008 | 04:36 PM
CPTAFW163's Avatar
CPTAFW163
Default Crank sensor swap
I got it out, but i couldn't use the hex wrench cause there was hardened dirt in there. So i used the bendable ratchet extension and it worked great. There was some clearance issues with the socket fitting over the nut with the head in the way, but i just kept pressing down on the top of the ratchet and kinda "hammered" it in place.
Here is the pic:
OPic won;t embedd so here is the link:
https://dodgeforum.com/albumtn.aspx?...j675196934.jpg
Hope this helps anyone that needs to do it. I had to sit in the engine compartment with the shock tower up my a$$.
